Re: 8N Flooding
Posted by JMOR on February 10, 2020 at 05:08:56 [URL] [DELETE] :
In Reply to: 8N Flooding posted by Cal Sexsmith on February 09, 2020 at 17:44:50:
turn off the gas at sediment bowl and try starting tomorrow. It should not "flood" then and start and run normally for about two minutes as it uses up the gas in carb float bowl.. If that is the case, then investigate float/needle/seat.
