8n hydraulic cover/seat mount location
Posted by Doug on January 29, 2020 at 15:26:36 [URL] [DELETE] :
I've got a broken bolt stem in the hydraulic cover/seat spring mounting location and before I start to attempt to back out the remaining portion of the bolt, I'm curious as to how thick the casting is at the location where the seat spring bolts into the hydraulic cover. Unfortunately, someone that owned the tractor previously had attempted to remove the bolt and really messed up the upper portion of the hydraulic cover's female tapped area. Depending on how much thread I have left in the hydraulic cover once the bolt stem is removed, I suspect that I may end up having to drill out and tap a new mounting hole in the cast cover and drill a new hole in the seat spring. Any advice or suggestions would be appreciated.
