Re: flywheel gear
Posted by mhb@ufe on January 16, 2020 at 07:44:34 [URL] [DELETE] :
In Reply to: flywheel gear posted by Scott on January 15, 2020 at 15:15:34:
I don't like to use the term "press fit" when referring to ring gears. The proper way to install it is to heat the ring gear so it swells and then let it shrink on to the fly wheel as it cools. That is what Bruce was referring to when he said ' heat it in the oven, freeze the flywheel' . Pressing the ring gear on will swell the ring gear and it won't shrink back down.
Mark
