Re: Golden Jubilee hydraulics
Posted by TheOldHokie on January 07, 2020 at 20:24:36 [URL] [DELETE] :
In Reply to: Golden Jubilee hydraulics posted by Gary A Ramus on January 07, 2020 at 18:50:29:
Start with the most obvious candidate - a leaking lift cylinder seal. You can visually inspect by removing the side inspection cover and looking for oil coming from the cylinder. The NAA cylinder uses a single o-ring with backup washer. Cheap and relatively easy to service.
TOH
