Re: Another 641 fuel valve replacement
Posted by Mike in Michigan on December 26, 2019 at 21:53:52 [URL] [DELETE] :
In Reply to: Re: Another 641 fuel valve replacement posted by Tim Daley(MI) on December 26, 2019 at 14:45:30:
Thanks for the reply Tim. Unfortunately I am down in Roch Hills area - a bit of a hike from you. The post was actually on another forum (https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=ford&th=500557) with the same Photobucket issue you described.
I did remove the hood by myself with no problem but still have to remove the bolts for the gas tank (4 small and 3 large, one is missing). After looking at the amount of clearance I had from the manifold I decided to stay with steel line. I was thinking of buying this:
https://www.amazon.com/Brake-Line-Kit-Coil-Fittings/dp/B01JP6SCD6/ref=sr_1_4?crid=L17PJM44DP9B&keywords=steel+brake+line+1%2F4&qid=1577411196&sprefix=steel+brake+line%2Caps%2C175&sr=8-4
I may still use the existing fuel line but noticed that it seemed to slant upward coming off the valve before going south. I thought that was supposed to cause vapor lock.
If I do decide to run a new line, is there any issue with trying to straighten out a roll like the one above? Probably not be since they sell so many. I have a flare kit and bending tool on my list.
Another thing I was considering on the valve rebuild, instead of replacing the rivet with a screw, how about just plugging it flush? Not sure what with. What would be the ramifications of not having a stop point for the screw?
And yet another question comes to mind, there were no rubber bumpers at all, like:
https://www.steinertractor.com/FDS377-Center-Door-Rubber-Bumper
https://www.steinertractor.com/FDS1759-Radiator-to-Hood-Side-Panel-Bumper
Are these helpful, and if so where do they get placed?
