Re: 9n has a Short
Posted by Dn-N-Tn on December 23, 2019 at 19:06:44 [URL] [DELETE] :
In Reply to: Re: 9n has a Short posted by R GEIGER on December 22, 2019 at 20:04:46:
From what he's describing----it sure sounds to me like the cut-out relay is stuck in the closed position. That would make it appear to be a short when the wire is hooked to the generator----when the wire is removed, the short goes away, and that's what should happen when the cut-out relay is working as it should and the engine quits turning the generator. The cut-out relay makes the generator and battery power source connect or disconnect depending on whether or not the generator is being rotated.
