Re: 9n has a Short
Posted by Tim Daley(MI) on December 23, 2019 at 12:43:40 [URL] [DELETE] :
In Reply to: Re: 9n has a Short posted by Dean on December 23, 2019 at 11:33:38:
If you have a n OEM generator, as with most all parts, best to rebuild rather than buy new stuff. But, your shop guy can also test and rebuild it as well if he know what he is doing. How did you test the cutout? The generator? The single wire is the armature and feeds to the ballast resistor terminal thru the ammeter and switch. I have OEM generators rebuilt and ready to go. If you want to send yours to me I can test it and fix/rebuild it or rade outright. Email is open.
PS: Do you have a tensioning bracket on your generator? Fan belt must be held tight in order to charge the battery effectively.
