Re: Distributor installation
Posted by Rusty 2N on December 11, 2019 at 12:15:47 [URL] [DELETE] :
In Reply to: Distributor installation posted by Jessie Peterson on December 11, 2019 at 11:08:32:
That front. Ount distributed only goes on one way! Look at the back of dist and you will see that the tang is not centered and is angled on one side, match that with the slot on the end of camshaft if it sits flat against the block with the bolt holes lined up it is correct.
