Re: hydraulic issue Ford 600
Posted by Jon Calder on December 03, 2019 at 08:22:46 [URL] [DELETE] :
In Reply to: Re: hydraulic issue Ford 600 posted by Ultradog MN on December 02, 2019 at 17:42:50:
Hi, am I better off ordering cam follower pin from CNH or will the ones available from aftermarket guys be OK? I read the NAA "how to" and I think I recall it advises CNH o-rings etc.
Is NAA essentially same as my 600?
I usually avoid TSC and YT.
Usually buy from DC and St. So far both of them have been good (for me anyway) and electrical from Bri.
Here's the really stupid question- the cylinder and piston is underside of the cover..? If that's the case when you remove cover (and all) where is the hydraulic piping connection? Pump is on side of engine correct?
I'm missing something?
Thanks, Jon
