Re: hydraulic issue Ford 600
Posted by Ultradog MN on December 02, 2019 at 17:42:50 [URL] [DELETE] :
In Reply to: hydraulic issue Ford 600 posted by Jon Calder on December 02, 2019 at 14:44:53:
You are describing classic symptoms of a badly worn or worn off cam follower pin. Get your I&T FO-20 manual out and read about overhauling your lift cover including adjusting all your linkages under there, putting new seals in your lift piston and replacing the cam follower pin.
