coil and distributor
Posted by Jessie Peterson on November 28, 2019 at 20:52:41 [URL] [DELETE] :
Just acquired a 1948 N that has been converted to 12 volt system. I need to replace the distributor due to a crack. If I find the coil bad can I use a 12 volt coil on the given distributor ? not sure if its 6 or 12 volt ...how do I tell and can I use either coil?
