Re: Rubber Washers Axle Shaft
Posted by Gregg on November 27, 2019 at 19:08:50 [URL] [DELETE] :
In Reply to: Re: Rubber Washers Axle Shaft posted by mhb@ufe on November 27, 2019 at 15:31:31:
I understand they changed the basic design of the outer seal, I have a pair of the one piece A8NN4248A seals as replacements.It is confusing making the change, what to keep, what is superseded, when it has been modified.Seems someone removed the inner seal, leaving only the seal lip on my 1950 1/2 heirloom and put in an extra of these.Maybe the original outer bearing went dry and an old school 9N, 2N mechanic thought this the remedy.
