Re: Rubber Washers Axle Shaft
Posted by mhb@ufe on November 27, 2019 at 15:31:31 [URL] [DELETE] :
In Reply to: Rubber Washers Axle Shaft posted by Gregg on November 27, 2019 at 13:43:14:
They call it a gasket in the parts look up. There should only be one and it is there to stop oil from leaking out the splines in the axle and hub. The new one will look much different as it won't be flattened out.
Mark
