Re: Torque Value Hydraulic Pump Bolts
Posted by Gregg on November 21, 2019 at 18:17:08 [URL] [DELETE] :
In Reply to: Re: Torque Value Hydraulic Pump Bolts posted by Gregg on November 21, 2019 at 17:34:12:
I would like to add something that probably will make some of you smile because have been there, done that.All this sump and pump work was part of a snowball deal, before I realized I had a hydraulic pump valve issue.I looked at the right axle trumpet, the brake backing plate, the right brake rod and saw damage from thirty years in a barn with calcium chloride dripping out of a bad tire valve.It is all interconnected so I find myself doing it all while the sump is empty.
