Timing
Posted by Lee W on November 16, 2019 at 15:19:17 [URL] [DELETE] :
I had an ant invasion on the coil on my '49 front mounted coil. I ended up replacing the coil, points, condenser. In order to get it static timed correctly, I had to fully retard the distributor. It seems to run fine but I'm concerned with the "why" this happened. Any input would be appreciated.
