Re: 9N single terminal generator overcharging
Posted by HCooke on November 10, 2019 at 08:19:48 [URL] [DELETE] :
In Reply to: 9N single terminal generator overcharging posted by Alex Abbott on November 09, 2019 at 16:10:39:
There is no voltage regulator on a 9N. There is a cutout which simple prevents current flow back to the gen when the engine is off. The only 'voltage regulator' is the adjusting screw. I cannot imagine how an over charging generator would make the engine miss at high rpm's. This sounds like a different problem.
