Re: Deiss
Posted by Ultradog MN on November 01, 2019 at 02:53:04 [URL] [DELETE] :
In Reply to: Deiss posted by Daniel on October 31, 2019 at 17:19:47:
Rims that will fit the 6 on 6" lug pattern are Very common.
That lug pattern was used on many tractors and also things like hay racks, balers, corn pickers, etc, etc.
It was used on all under 80 horse Ford tractors from 1948 till well into the 1990s including Jubilees, 600,801, 2000, 3000, 4000, 5000, 6000, 7000 and a huge number of derivitives of those models.
They are available aftermarket in 14", 15", 16", 18" and 20" sizes and probably from 4"-12" widths.
You can get them in several different offsets.
Your local ag tire man can probably get you whatever size/width/offset you want. If not, contact Pioneer Rim and Wheel in Minneapolis, MN or Fargo, ND. They can get you anything. I put new 6x14" rims on my 3000 and ran those for about 10 years then replaced them with 900-10 TEN PLY! tires/rims a couple of years ago. All would be direct, bolt-on replacements for you.
There are lots of choices out there.
