Re: Head Studs
Posted by K.LaRue-VA on October 22, 2019 at 13:24:27 [URL] [DELETE] :
In Reply to: Re: Head Studs posted by Edwin Douglas on October 22, 2019 at 11:41:07:
The three longer studs were used where extra thread length was needed to attach the wiring tube to the top of the engine with a second nut. Check your cylinder head thickness before you buy bolts or studs. Some replacement heads are thicker castings. Leaving studs long can be a problem when it comes time to change spark plugs. Those threaded studs sticking up will do a number on your knuckles.
