RESISTORS
Posted by Tim Daley(MI) on October 22, 2019 at 10:43:13 [URL] [DELETE] :
In Reply to: Re: front mount coil voltage posted by Tim Daley(MI) on October 22, 2019 at 10:17:16:
These pictures may help...
FORD OEM BALLAST RESISTOR -USED ONLY WITH FRONT MOUNT DISTRIBUTOR:
HELP: The LH resistor Terminal Post connects to the COIL Stud Terminal Post as you face the back off dash.
EXTERNAL 1-OHM CERAMIC RESISTOR - USED ON FRONT MOUNT ONLY AND ONLY IF COIL IS 6V:
