Re: front mount coil voltage
Posted by Tim Daley(MI) on October 22, 2019 at 10:17:16 [URL] [DELETE] :
In Reply to: front mount coil voltage posted by Ed on October 22, 2019 at 07:26:29:
A '49 would indicate a front mount distributor, that is more important to know than a model year or a serial number. So, using JMOR's fine document on wiring, find your setup and follow it to a T -no shortcuts allowed. Do you have the Ballast Resistor? Is the Voltage Regulator still in the circuit? It shouldn't be if using 12V. There is no voltage adjustment. You set up the system for whatever you are using (6V/POS GRN or 12V/NEG GRN)and that's it. With a 6V Coil you need to add an inline ceramic 1-OHM resistor. Best to buy a 12V coil and do away with the external resistor altogether.
tpd
