Re: Head Studs
Posted by Tim Daley(MI) on October 22, 2019 at 04:42:35 [URL] [DELETE] :
In Reply to: Head Studs posted by Edwin Douglas on October 21, 2019 at 18:04:25:
HiYa Mister Douglas-
Everyone seems to be going with head bolts these days. Here's a 7/16-14 x 7/16-20 x 3.00 stud, Grade 8, from SUMMIT RACING. It was the first place I looked so there may be others; allenfasteners for one. Note length is 3". OEM specifies 3 at 2.9" and 15 at 2.78" so if you must, grind off the 7/16-20 end that accepts the hex nut. Use an old one to compare with. Torque is different for nuts and bolts. The UNC (coarse) end, 7/16-14 always goes into cast iron. The UNF (fine) end, 7/16-20 accepts the hex nut. LINK for studs below, LINK for hex nuts listed in text. Hope this helps you.
FORD FLATHEAD TORQUE VALUES:
REF: 7/16-20 Hex Nuts: https://www.mcmaster.com/95036a037
Tim *PloughNman* Daley(MI)
*9N653I* & *8NI55I3*
