Re: 2n engine stuck after clutch
Posted by Roland (AL) on October 21, 2019 at 21:46:58 [URL] [DELETE] :
In Reply to: Re: 2n engine stuck after clutch posted by Den N Ms on October 21, 2019 at 01:07:46:
I did not spot weld the ring gear. I changed the crank to flywheel bolts, and the pressure plate bolts with the same length bolts. As soon as I can I am going to try to look in the plug hole and see if I can see anything. If nothing I will split again and see what the problem is. I will update as soon as I figure it out. It was free and smooth before now this. One step forward three back.
Later
Roland (AL)
