Re: 2n engine stuck after clutch
Posted by Den N Ms on October 21, 2019 at 01:07:46 [URL] [DELETE] :
In Reply to: 2n engine stuck after clutch posted by Roland (AL) on October 20, 2019 at 19:43:48:
Roland,You didn't happen to spot weld the ring gear on to the flywheel did you?
Did you replace ant bolts in the flywheel or pressure plate with any longer/different bolts?
