2n engine stuck after clutch
Posted by Roland (AL) on October 20, 2019 at 19:43:48 [URL] [DELETE] :
I replaced the ring gear, clutch (turned the right direction), pressure plate, release bearing, and trans seal. When I got the engine back in the starter would not turn it over. I pulled the starter and it worker fine, put it back in and no go, pulled the plugs and no go, used a long screw driver in crank nut and got it to move. Tried the starter again and it moved it about 2" and stopped. I backed the engine up and it stopped turning after about 2". I guess I will pull it back apart and see what is stopping the engine. The only thing I can think of is the ring gear is hitting the starter. Anybody ever run into this before.
Roland (AL)
