Re: 9n 3 point hitch issue
Posted by JMOR on October 19, 2019 at 08:37:41 [URL] [DELETE] :
In Reply to: 9n 3 point hitch issue posted by Ed Douglas on October 18, 2019 at 22:57:29:
Remove right side round inspection port and feel to see if control valve is moving as you operate touch control lever. Valve may be stuck or the control arms may not be attached to valve. A spring between control arms and the front end of ram cylinder acts to cause the touch control lever to rise. The cork disc and and spring assy at base of touch control lever resists this movement & is probably missing, worn, frozen to shaft, so not resisting
