Re: 860
Posted by JMOR on October 16, 2019 at 15:43:22 [URL] [DELETE] :
In Reply to: Re: 860 posted by Jack - Iowa on October 16, 2019 at 15:06:38:
Compression isn't instantaneous, as it begins to build as the piston starts travel up the bore and continues to build as it compresses the cylinder volume, pretty much for the 100-180 degrees of crankshaft rotation, and peaks as it reaches TDC-compression. As for assembled wrong.....well, it has been running fine and hasn't been re-assembled, has it?
