Re: 860
Posted by JMOR on October 16, 2019 at 10:02:41 [URL] [DELETE] :
In Reply to: Re: 860 posted by Jack - Iowa on October 16, 2019 at 08:50:06:
If all your work is good, it sounds like I agree, however, the pin in gear could be sheared or the weld holding advance plate to shaft could have failed? If you aren't ready to pull distributor to investigate, I might see if the same 90 position repeats of if it changes with each attempt. If something in gear, pin, plate is amiss, I would expect it to keep changing.
