Re: Nolde
Posted by TheOldHokie on October 12, 2019 at 10:20:47 [URL] [DELETE] :
In Reply to: Re: Nolde posted by Farmer Dan on October 12, 2019 at 07:29:25:
It is not the same as what you had on that 9N where the pull point was the bolts on the back of the PTO casting. She has an 8N with OEM under axle drawbar clevis which uses the 4 factory under axle drawbar studs as the pull point.
TOH
