Re: 8N Hitch Setup
Posted by Farmer Dan on October 12, 2019 at 07:20:02 [URL] [DELETE] :
In Reply to: 8N Hitch Setup posted by Ken Carlsen on October 11, 2019 at 11:03:45:
I shattered the center housing on my 9N by not using the correct towing equipment. I replaced it with the center housing from a 8N and a swinging drawbar. I use this setup for tractor pulls. I need a 3" hole to hook the sled to but you can replace that with a ball or what ever you need. IT is well below the axle so flipping the tractor will not happen. Trust me I've tried several times.
https://youtu.be/PgqXp1RW3Xs
