Re: Nolde
Posted by TheOldHokie on October 11, 2019 at 18:16:12 [URL] [DELETE] :
In Reply to: Nolde posted by Patricia on October 11, 2019 at 10:58:03:
The drawbar is home brew and uses the OEM drawbar bracket. It will work fine as long as you limit the tongue weight to say 100# or so.
You can purchase the sda06 aftermarket drawbar kit for the tractor which has a support for the drawbar and is better suited for a larger tongue weight.
TOH
