Re: 8N hitch
Posted by K.LaRue-VA on October 11, 2019 at 15:50:21 [URL] [DELETE] :
In Reply to: 8N hitch posted by Patricia on October 11, 2019 at 11:00:01:
The part bolted to the tractor with the push and turn pin is the original 8N part. The part swinging on the pin is the Ho-Made thing Tim mentioned. It looks like that hitch can flop around some on the pin. Seems like a longer bar would be better. It would allow tighter turns before whatever you are towing hits the tires. The photos provided show some of the aftermarket setups that are available. Most of those are going to be better designed and work better than what you have.
