Re: Changing drag links
Posted by Tim Daley(MI) on October 02, 2019 at 04:57:22 [URL] [DELETE] :
In Reply to: Changing drag links posted by StormCloud601 on October 01, 2019 at 21:16:38:
HiYa Cloud-
Technically the 8N is a '48, early steering box used from '48-'50. John Smith once said after doing one of his early box rebuilds if he ever did it again he'd go and install a late box. You are correct that early boxes and late boxes are different, but don't know if any other changes are required. The SEP 1952 MPC has a chart with all the drag links, so if you want a better picture, get out your copy to see. Lengths are factory references only, not etched in stone, so actual lengths will vary, but gets you a starting point.
