Re: Gas Leak
Posted by Frank (WNY) on September 26, 2019 at 12:31:08 [URL] [DELETE] :
In Reply to: Re: Gas Leak posted by Tim Daley(MI) on September 25, 2019 at 17:49:25:
Thanks Tim and Kevin, I have been buying all my 8N parts from Just 8N's because they are so knowledgeable like you guys. I probably should have bought a new fuel line when I replaced the valve, then again, when I rebuilt the carb and replaced the inlet elbow. I guess I will place a order for it and buy another valve in case the leaky valve turns out to be something other than junk in the fuel that became lodged in it. That way I can replace the stem first and if that doesn't work I will replace the whole valve assembly. Also, the gas leaking around the carb destroyed the hose from the air cleaner, so I will get a new one of those too. Thanks again, Frank
