Headlights on NAA
Posted by Larry on September 23, 2019 at 22:52:04 [URL] [DELETE] :
My NAA has the original lights, but the switch appears to have been broken. It is a simple toggle switch so I don't know if that is original. The tractor has been converted to 12 volts. I assume I'll have to replace the original lights with 12 volt lights and fix the switch. I don't know the history of the tractor, so any info you can provide will be much appreciated. Thanks
