Re: starting 6v 8n issues
Posted by R Geiger on September 18, 2019 at 18:14:47 [URL] [DELETE] :
In Reply to: starting 6v 8n issues posted by DCarr on September 18, 2019 at 17:15:10:
gonna assume a side mount dist, did you set number 1 cylinder at TDC on the compression stroke when you reinstalled the dist. be advised there are two set of timing marks on the flywheel.
no fire with starting fluid means you are not getting start when you need it.
