Re: What size over run
Posted by Ultradog MN on September 17, 2019 at 17:15:56 [URL] [DELETE] :
In Reply to: What size over run posted by David on September 17, 2019 at 10:51:54:
Do yourself a favor and if it isn't already 1 3/8" convert it. Everything nowdays is made to connect to a 1 3/8". Then buy a push button type ORC.
They're Sooo much easier to put on and take off. Sooo much safer too.
I always hated that orc spinning back there every time you wanted to use the 3 point. Yes, a guy can take the type with the roll pin off and on too but a guy gets lazy and thinks: "I'm just gonna use the boom pole for a couple of minutes to lift this log or engine or tire off the trailer."
So you use it with that orc spinning and it's just unsafe as hell.
Photo shows the good kind. They cost more but they're worth it IMO.
