Re: 52 8N trans/hyd/RE fluid change
Posted by K.LaRue-VA on September 16, 2019 at 16:20:46 [URL] [DELETE] :
In Reply to: Re: 52 8N trans/hyd/RE fluid change posted by K.LaRue-VA on September 16, 2019 at 15:43:05:
As far as that fluid goes, the label says "recommended for...". Nothing on that label says it "MEETS" 134D spec. The manufacturer apparently "recommends" it as a replacement fluid. It's probably ok, but I would do a lot more research rather than just going by what some marketing folks decided to put on the container.
