Re: Block swap question
Posted by Kirk-NJ on September 06, 2019 at 02:55:59 [URL] [DELETE] :
In Reply to: Block swap question posted by Doug siperly on September 05, 2019 at 19:20:44:
Should be able to make the switch. You will need the camshaft. I have a 48 front dizzy block that was changed to a side. Mounting holes for the generator will be on the wrong side of the block so check to make sure all will mount up
