Re: Ford 600 tank shut off
Posted by HCooke on September 05, 2019 at 11:42:14 [URL] [DELETE] :
In Reply to: Ford 600 tank shut off posted by Jon Calder on September 05, 2019 at 10:13:12:
"My question(s): is this original equipment?"
Yes.
"Should I shut this off when not using tractor or the valve on the sediment screen?"
Highly recommended. This is a gravity feed fuel system, if you float needle valve fails in the carb you will flood the carb and possible the engine. Lots of posts on this topic. I can turn that valve by hand on my 641.
