Re: Putting 8N back together
Posted by Cal Sexsmith on September 01, 2019 at 07:50:50 [URL] [DELETE] :
In Reply to: Re: Putting 8N back together posted by Bruce Dorsi on September 01, 2019 at 07:42:17:
I used a homemade pilot shaft to centre the clutch. Measurements indicate that vertical alignment is OK, but horizontal alignment is a bit off. I am going to try backing things off a few inches to see if I can straighten things out. I may try depressing the clutch pedal first to see if that helps.
