Re: Putting 8N back together
Posted by Jack - Iowa on August 31, 2019 at 19:36:15 [URL] [DELETE] :
In Reply to: Putting 8N back together posted by Cal Sexsmith on August 31, 2019 at 19:24:12:
Others are much better qualified to answer you than I am. That said, are the two halves level to each other? Perhaps easiest check is to observe your space. Is it equal top to bottom. Must be or it will not slide together. On my 860 I had not pulled the PTO shifter which caused me the opposite problem. Must be level and in line side to side.
