Re: 8N Stopped Firing Up
Posted by Anthony on August 25, 2019 at 16:43:21 [URL] [DELETE] :
In Reply to: Re: 8N Stopped Firing Up posted by Bruce (VA) on August 25, 2019 at 09:36:05:
the starting slowly got harder over time and it sits up alot. So I did make the mistake of just guessing the carb was clogged up as I had replaced distro components recently.
I moved on to spark since the new carb didn't work. I will certainly get a spark checker and try to be more wily in the future. I wasn't blessed with the most common sense, certainly.
OK
Engine cranks, won't start.
12 Volt conversion
Front Distro
Fuel flows well - clean bowl screen and fresh inline filter.
My next step is to go out and properly check for spark. It may be next weekend. I have a splitter of a headache today.
Thanks, again for all the help guys. I'll get her running with with your help- no doubt.
