Re: 861 Powermaster Pie Weights
Posted by WayneIA on August 23, 2019 at 19:09:40 [URL] [DELETE] :
In Reply to: Re: 861 Powermaster Pie Weights posted by Kirk-NJ on August 23, 2019 at 14:51:32:
I see nothing wrong with the way the rim is set or the position of the weight disc. The problem will be if you are going to use the HD "40# weights". The four that line up with the PW adjusting clamps won't fit. Since you have Power Adjusted Rear wheels, you would be better off with the 800# set. "35# weight". There is a 1200# set made for 24" rims that will work in this situation.
