Re: Sporadic Rad coolant leak
Posted by Beth and Allen on August 20, 2019 at 19:30:14 [URL] [DELETE] :
In Reply to: Re: Sporadic Rad coolant leak posted by Farmer Dan on August 20, 2019 at 14:33:29:
A couple of things I,ve run into is if the antifreeze to water ratio is too high it will find even the smallest of holes to leak from. Another thing is maybe a clamp isn't quite tight enough, it holds good while warm but when every thing cools down and things shrink it leaks.How old are your hoses,sometimes they get old and brittle and start getting small cracks that leak when cold. Just my 2cents worth. God Bless,Beth and Allen.
