Re: Ford 8n Front loader Control Rebuild kit
Posted by TheOldHokie on August 18, 2019 at 12:37:59 [URL] [DELETE] :
In Reply to: Re: Ford 8n Front loader Control Rebuild kit posted by Josh on August 17, 2019 at 19:55:06:
Send me an email - oldhokie@windyridgefarm.us.
Based on the old loader valve on eBay that you linked I would guess you have a Wagner WM3 loader. And after going back through my records I see the Prince valve in my picture is identical to the one iyou found at Northern tool. My valve was used to replace the valve on a WM3 loader but it really doesn't matter what loader it is. The valve can be mounted and used on just about any of the old Wagner or Dearborn loaders. You will need some additional hose and fittings to match the ports on the new valve up to the hoses/pipes on the loader. If the old hoses are showing any signs of cracking or the pipes and fittings are in poor shape it might be a good time to consider replacing them along with the valve.
TOH
