Re: 8n seat spring mounting studs
Posted by TheOldHokie on August 07, 2019 at 08:28:10 [URL] [DELETE] :
In Reply to: Re: 8n seat spring mounting studs posted by Doug on August 06, 2019 at 20:19:25:
I hope you are a skilled welder if you go this route. My guess is the reason it is broken off is it is so rusted in place it is not going to come out except in pieces. I expect it will require drilling it out all the way to the threads. And if you don't get that exactly right a thread repair insert is probably in your future.
TOH
