Re: 8n seat spring mounting studs
Posted by Doug on August 06, 2019 at 19:17:02 [URL] [DELETE] :
In Reply to: Re: 8n seat spring mounting studs posted by Dn-N-Tn on August 06, 2019 at 18:51:18:
Thanks for the idea. Unfortunately, the stud is broken off approximately 1/8 of an inch below the top. I am/was hoping that the threaded stud doesn't have a head that resides under the top of the case. I will look at using a screw extractor if there is no bolt head or some type of mechanical "fastener/head" holding the bolt in the case.
