8n seat spring mounting studs
Posted by Doug on August 06, 2019 at 17:38:39 [URL] [DELETE] :
I have a 1950 8N that has only one of the two studs that the seat springs is held to the top of the hydraulic case still in tact. The second stud has broken off below the level of the hydraulic case. Has anyone attempted to remove/extract a threaded stud that I am referring to? I'm not sure if the stud passage is a thru passage into the hydraulic case or exactly how the stud is seated into the case. Before I go and tear up something unnecessarily, has anyone had experience extracting one of these studs and replacing? Thanks
