Re: NAA Jubilee Dies With Load
Posted by Dead Eye Dave on August 06, 2019 at 04:41:14 [URL] [DELETE] :
In Reply to: NAA Jubilee Dies With Load posted by Don G on August 06, 2019 at 04:24:10:
There are two other screens to be checked and cleaned, one is attached to the inlet to the carburetor while the likely suspect is attached to the top of the fuel valve into the bottom of the gas tank. To check this one requires draining the tank and removing the valve. If the tank has a lot of crud it will need to be flushed. Just my thoughts. Dave
