Re: "frozen" up
Posted by steveVa on August 01, 2019 at 21:18:18 [URL] [DELETE] :
In Reply to: "frozen" up posted by Tom Keith on July 31, 2019 at 11:18:26:
I would take some gas and mix with 2 cycle oil about 20 to 1 ratio.
Drip a oz or 2 into each cylinder. Make sure tractor is turned off and or disconnect battery so it will not start. Then shift it into high gear. Then Stand beside the rear tire and with both hands rock it back and forth. Once you get a rhythm going it should break it loose. I would not tow it with engine stuck you will bend or break something.
